Service B
Old Sep 20, 2005 | 02:26 AM
ANDOLINI's Avatar
Service B
I Just Spent 545 Dollars For Service And The Car Has 34000. The Price Included The Cabin Filter Replacement. I Thought It Was Little Too Steep. What Do They Do In Service B Besides Change Oil And Filter. Can I Change Cabin Filter My Self..
Old Sep 20, 2005 | 04:51 AM
carlsson9's Avatar
Mercedes W210 E280
I believe someone did post a pretty detailed look plus pictures in changing the cabin filter..i also just changed mine..but made hell a lot of difference..the filter was about US50 though here in malaysia.
However, you'll start to see that servicing and upkeeping a merc can be very expensive..regardless what service interval comes up..:P
Old Sep 20, 2005 | 03:59 PM
dcfsf's Avatar
2003 E55
26,000 Miles: B-Service
(AMG/V12 Models at 20k Miles)
- Engine oil change and filter replacement (includes factory approved Mobil 1 synthetic oil)
- Inspect and rotate tires, check tread depth, and adjust tire pressure. (models with staggered wheels include tire pressure adjustment and checking tread depth)
- Brake inspection including check of pad thickness and condition of rotors, fluid & lines.
- Inspect cooling system.
- Check for fluid leaks.
- Replace dust filter.
- Brake system fluid flush.
- Replace washer solvent
$345.00 @ caliber motors
Old Sep 20, 2005 | 04:03 PM
slvrstar's Avatar
clk
I don't know where you live, but over $500 for service B is steep. Dealerships only costs around $300.
Old Sep 21, 2005 | 12:43 PM
ccmbduong's Avatar
Service A & B
You can do most of those services by yourself. Call your MB dealers and ask what things that will be performed (sometime they list them on their websites). What you find is most things are check this...check that... and you can check them. Look into what they will REPLACE, then go to an independent MB garage and ask them to do them same thing. You will save a lot of money that way. I change oil and spark plugs, I let them flush radiator every 3 yrs or 20K miles, I ask them change trans oil every 60K miles... That's ALL I have to do and save a lot of money. I have '96 E320 for almost 5 yrs, bought it used, and I've spent less than $500 so far
Old Sep 21, 2005 | 02:56 PM
sbarsap's Avatar
13 Lunar Blue GL550, 06 Imola Red BMW X5 4.8is, 04 Gold Honda Ody
Service B is around $450.00 at MB stealerships here in Houston.
You can probably get it done cheaper at indy shops.
IT's basically a glorified oil change.
You can do the cabin filters yourself, really easy. Do a search on this forum.
Some places replace the windshield viper rubber too.
Old Sep 21, 2005 | 03:36 PM
Air Marshall Eldritch's Avatar
John Deere
My dealer also washes the car.
Wheeeeeeeeeee!!!
