transmision
Old Sep 24, 2005 | 04:31 PM
traianusa's Avatar
transmision
I have a '95 E420. It feals that the transmision is shifting rough when the engine and the transmision are cold. After that it's fine. What should I do to fix the problem? Thank you
Old Sep 24, 2005 | 06:43 PM
Alexbenz's Avatar
Sean's Sister--
thats normal......you should let your car warm up a bit before you drive.....
Old Sep 24, 2005 | 08:50 PM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
The transmission delays shifting when it's cold to help it warm up more quickly. Because the shifts are delayed, your engine will rev higher. Shifts at high RPM (but not much throttle) are a bit rougher.
It's best to let your car idle for about 30 seconds after you start it until the RPM sits down below 1000 RPM. Then just drive very gently until it's fully warmed up. The problem with letting your car warm up idling is that your engine runs cold for a very long time. It's better for your engine to warm up more quickly by driving gently than to warm up slowly at idle. If in doubt, read the manual...
Old Sep 27, 2005 | 07:18 AM
traianusa's Avatar
Thank you for your advise. I will follow your advise and I will keep you posted.
Old Sep 27, 2005 | 08:14 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
When's the last time the tranny fluid was changed or flushed ? That might be your answer.
Old Sep 30, 2005 | 02:06 AM
Eklass420Spt's Avatar
97 E Klasse 420 Sport/ 90 Honda Accord EX/97 Impreza Coupe
i get that also but ppl who drive the car don't listen i.e. my dad drives the car on the weekend he jus starts up and drives it not letting it warm up i always yell at him for that.
