engine "hum" in cabin
Old Sep 25, 2005 | 07:50 PM
enzo430S's Avatar
MB E430 Sport
Hi,
I'm new to the W210 and I have a E430 Sport. Ever since I got it, I'm hearing a dull, low hum in the cabin while the motor is running. This occurs with or without the AC being turned on. Is this normal or do you think I have a problem? The hum seems to get more apparent as the engine temp goes up past 80 degrees.
Old Sep 26, 2005 | 09:51 AM
Ala-benz's Avatar
'00 E430, '83 Porsche 928S
You may want to check your motor mounts. They are filled with oil from the factory and they tend to flatten out over time (and leak). Once they flatten out, you will get more engine noise transferred to the body. I am sure that are fifteen other things to check, but this forum is usually pretty good to give you plenty of things to look for.
Good Luck and welcome.
Old Sep 26, 2005 | 02:36 PM
enzo430S's Avatar
MB E430 Sport
Thanks. I'll go check that out.
Old Sep 27, 2005 | 10:26 AM
Rocky Gauthier's Avatar
E320
I had a hum in my car, and it turned out to be the fuel pump. My was located in the left rear panel.
Old Sep 28, 2005 | 07:52 PM
enzo430S's Avatar
MB E430 Sport
how many miles did you have on your car when you experienced this?
Old Sep 28, 2005 | 08:13 PM
E320
I have a 2001 E class with only 15000 miles on it. I think I had it changed at 10,000 miles. My dealer said that this was only his 3rd fuel pump he had to change on this type of car. But, we are a population of only 100,000+. Hope this is the problem for you, because it would be an easy fix. Good luck.
