will these wheels fit?
These are the same rims as the one I am considering. The guy wants $900 for rims and new tires. Any help is appreciated.
Bear in mind also that if u space out the front, the rear's might appear to stick in disproportionately, that could be an issue but more on looks.
My advice, unless u really must have them, is to go for another wheel that fits properly.
When you indicate that when the rim was mounted, the caliper "rubbed" or touched the wheel. I assume that it was the back of the wheel to the outer edge of the brack caliper, is this correct?
If you go to the "other" forum post about projector headlights, you can see the owner "foreyes" is running similiar 17" 3 piece wheels. I think the 16" wheel must have a little more material near the wheel hub as the 17's are used without a spacer.
http://www.benzworld.org/forums/foru...osts=26&fid=17
