Where's the Heat?
Any suggestions as to what it could be?
then the next most likely culprit is the damper doors which allow metered
air to circulate into the cabin. sounds like they're not opening
What happens if you leave it on automatic. I notice that it takes a while for our 04 E500 to heat the cabin as well but auto seems to do the best for us.
When it is cold outside and the engine at operating temp, the vents blow warm (not hot) air. I have to turn the fan on MAX and the air takes a long time to heat the cabin. My first thought was that the temperature sensor inside the car ws faulty, but the dampers seem to be the first things to check.
Any other ideas?
