HELP - Decipher scan codes (and fix?)
Code---------Text-------------------------------------------Status
ME2-SFI – Motor Electronics 2.8
P2043 Misfiring (See currently valid STIP) (P0300) STORED
P2044 Misfiring of cylinder 1 (See currently valid STIP) (P0301) STORED
*For this the mechanic suggests replacing all 12 spark plugs, $21/each and 6 coils(?), $127/each, totaling $1,900……
ESP – Electronic stability program
C1200 S9/1 (Stop lamp switch) Plausibility STORED
C1024 Fault in CAN communication with control unit N15/3 (ETC control module) STORED
C1504-009 The system is switched off. Steering angle sensor is not initialized STORED
EIS – Electronic ignition switch ELCODE
B1858 Is actual value S40 (CC switch) plausible? STORED
B1056 Fault in CAN communication with control unit DCM-RL STORED
PSE – Pneumatic system equipment
B1712 The alarm has been activated through component S17/3 STORED
B1709 Component H3/1 is not coded or FAULTY STORED
SAM - Signal acquisition and actuation module
B1217-000 Fault in communication with component B38 (Rain sensor) STORED
B1217-003 Component B38 (Rain sensor) has excess temperature STORED
* It seems my rain sensor works perfectly, at least during the very few rainy days this fall
ICM – Instrument cluster with maintenance interval display
B1108 Fault in CAN communication with control unit N73 (EIS control module) STORED
B1111 Fault in CAN communication with control unit A35/8 (Tele Aid control module) STORED
AUDIO
N1141 Set-actual configuration of D2B ring differs Current and stored
N1112 No data transfer between D2B master and D2B predecessor component possible STORED
N1140 CAN bus-fault
E-call [USA] – Telematic system
N1004 GPS positioning is not assured STORED
N1100 No signal is received from the right-side speed sensors STORED
N1101 No signal is received from the left-side speed sensors STORED
AAC – Automatic air conditioning
B1234 B32 (Sun sensor) STORED
B1416 A31m1 (Coolant circulation pump) STORED
Please, any “translation” to a normal language is appreciated. Suggestions on what/how to do are blessed and can also serve other members in future occurrence.
Thanks in advance,
A.D.
