E430 Power Steering Fluid
Old Jan 23, 2006 | 11:16 AM
bogene2020's Avatar
Is there a way to put power steering fluid in the E430 . I have a 2001 430 . Thanx
Old Jan 23, 2006 | 01:59 PM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
Yes. Pour it in the power steering fluid reservoir. You'll need to lift the front right corner of the plastic engine cover to access the power steering reservoir & dipstick.
Old Jan 23, 2006 | 02:17 PM
E320Star's Avatar
2000 E320 Sedan
Why do u want to add more power steering fluid !!! If u noticed it being low, then you shouLD KNOW how to add more !! If it is low, then you must have a leak somewhere !!
Old Jan 23, 2006 | 02:33 PM
bogene2020's Avatar
It is starting to make that humming sound . I think I found it under the black cover with the star . Do I have to use the mercedes P/S fuid ?
Old Jan 23, 2006 | 06:30 PM
lexrex's Avatar
Yes, you need to use MBZ P/S fluid, and be sure that you do not overfill it! There are hot & cold markings on the dipstick. Be sure to use the marking appropriate for the temperature of the fluid.
Old Jan 23, 2006 | 11:47 PM
bogene2020's Avatar
