Some kind of oil leak from under the car.
Old Feb 14, 2006 | 08:44 PM
BenzVince's Avatar
09' E350, 01' Maxima SE, 93 Nissan Maxima SE, 1987 Nissan Maxima SE
I noticed a little puddle of oil spot when I pulled out the driveway. I thought it was a motor oil leak. But this one is clear oil. I can't figure out where it was coming from. I suspected from the powersteering pump. That I think a possiblity of hose might be cracked or leaking. What do you think guys?
Old Feb 15, 2006 | 12:49 AM
zam2000's Avatar
S, GL, Escalade ESV, my shoes
It's likely the power steering oil, happened to mine too. Dealer offer to change the entire rack & pinion for $1800-2000 (part + labor).
Here's the good news: you can fix most of the problem. Go to Pepboys, buy a little pump and pull out oil from the power steering oil resevor (almost empty them), then put in a can of Steer-X (from PepBoys too), Make sure you do not overfill it. It will recondition your pinion seal & you will be fine.
I was in doubt when people show me this on the other forum (mercedeshop), but it's been years since I did this, and thing have been fine. I later found out that the gentlemen who gave me the tip was a Master ASE, specialize in Benz (those who surf that forum often will probably know who he is).
Another tip I learned from him: Trans-X fix most of the slip & retard problem in the 772.6 transmission (98-later). Most shop or dealer would simply ask you to replace the trans ($3-4K).
Do not use any other type of stop leak on your car. Also, Trans-X only work if the retard/slip in the trans is due to iregular oil flow in the trans (clog), and even trans service can't fix these problem (amazingly, Trans-X can). Similarly, Steer-X only work if leak is due to seal hardern. If you trans or steering really go kaput, broke, crack, or mechanically ruined, then the only solution is to fix/replace them.
Nevertheless, to each his own, I'm just sharing w/ you my experience.
