ASR light - no acceleration
Old Feb 25, 2006 | 06:30 PM
benzuser's Avatar
Hi,
I have a e420, 1997....I had the car sitting in the garage for over 2 months - cranked it up without problems, but left it running for a few hours by mistake till it ran out of fuel.
Now, the car shows ASR ligt, Check Engine Electronics and has zero acceleration power, even on idle.
I would appreciate any information, before I take it to a dealer...dreading the expensive repairs...
Thanks in advance.
Old Feb 26, 2006 | 10:56 PM
E-Klasse's Avatar
W205 C300
First thing is to read the codes off of the OBDII port. This will tell you where to look next. Next check the fuses to see if one may have blown in the ASR circuit. Check the ASR switch near the window switches. Check the brake pedal switch under the dash. After you know what fault codes are present, try to disconnect the battery and clear the codes or when you get them read, have them cleared. See if operation returns to normal and if the CEL or ASR warnings come back on.
