crazy windows
Old Feb 26, 2006 | 11:57 AM
tom's e320's Avatar
crazy windows
I left my 99 e320 sitting for about two months and of course the battery died. Had a new one put in and for some reason the windows now don't work properly. They will go up a couple of inches at a time anfter repeatedly pushing to "up" buton...could that be from the battery drain....suggestions?
Also, code needed for radio...do I have to get that from the dealer?
I'm a newbie and really appreciate your help!
Old Feb 26, 2006 | 01:53 PM
raymond g-'s Avatar
99 E320
use SEARCH feature
type words "resync windows"
limit to W210 forum
should tell you why it's doing that and the fix
Old Feb 26, 2006 | 02:56 PM
tom's e320's Avatar
Thank you sir!
Old Feb 27, 2006 | 10:41 AM
mrbill222's Avatar
1997 E420
If you call the dealer service department with the vin # they can giv you the code to unlock the raido. i did it.could not belive they would do that. I had a suburban have that hapen and it cost me $400 to get it unlocked.
Old Feb 27, 2006 | 05:21 PM
Richard / E320's Avatar
2001 E320
From my 2001 E320 Owner's Manual / Syncronizing Power Windows:
If the power supply was interrupted (battery disconnected or low) the windows cannot be opened by the Express feature.
To resynchronize the Express feature, press ^ (up) side of the power window switch until the window is completely closed and hold for an additional 2 seconds. Repeat procedure for each window.
The automatic full opening and closing procedure should now be restored.
