Power Steering Problem
Old Feb 27, 2006 | 10:08 PM
RaZCaL's Avatar
Hello. I have a 2002 E320. Recently my steering wheel is squeeking whenever I make a turn. I figure my power steering fluid is low so I would like to add some. Can someone help me locate the reservoir? Also, how much fluid should I put in? Is there a way to measure it? TIA
PS- A diagram of exactly where the reservoir is located would be much appreciated. Thanks.
Old Feb 28, 2006 | 08:31 PM
livetodrive's Avatar
2001 E-430 4-Matic
My steering wheel squeaked. M-B greased it a few times, and eventually replaced the entire rack under the warranty. It sounded like it was coming from the steering wheel column. You might want to stop by the stealer and have the technician listen to it.
Old Mar 2, 2006 | 08:28 PM
Petmerctech's Avatar
Are you still under warranty? The dealer will reseal the rack and replace the steering column boot and disc to eliminate the squeaking.
