How to change rear interior light?
Old Mar 18, 2006 | 07:01 PM
E320se's Avatar
2002 E320 Special Edition
The rear interior light in front of the rear window headliner goes out. The one turns on when you open the door. Does anyone know how to remove the cover? I am suspecting a blown light bulb but just want to check before getting part.
Appreciate your help...
E320se
Old Mar 18, 2006 | 09:02 PM
zam2000's Avatar
S, GL, Escalade ESV, my shoes
E320se
Get a flat-head screw driver, and ply it out, slowly
Old Apr 2, 2006 | 10:40 PM
E320se's Avatar
Finally got time to replace the bulb and fairly straight forward thanks to zam2000. But it turns out not the bulb perhaps something else down the wiring. I am suspecting the fuse and can someone please give me a pointer on where this fuse is located? I mean the actual fuse compartment (inside the passenger area or under the hood) plus the fuse location.
Thanks ahead.
E320se
Old Apr 2, 2006 | 11:33 PM
raymond g-'s Avatar
99 E320
fuse map/legends should be affixed to cover both in engine compartment as
well as in recess on dash...closest to driver door. from 99 E320.....
