Wheel/tire info needed. please read
Old Mar 24, 2006 | 04:45 PM
smazur's Avatar
I'm in a 97 E320 and am looking for a wheel and tire upgrade. I've contacted a local seller to ask him about an advertised set of these:
(Carlsson AMG Mercedes rim + Potenza S-02 255/40 ZR 19).
Can anyone tell me if these tires will fit my E320 currently with 215 55 16 on them and if I would need any new lugs/spacers etc for them...
Also, while we're at it, can you explain what benefits I'd get by upgrading to a larger radius wheel/tire set? I'm assuming I'd get better ride and handling but why? Is it the sidewall, the larger circumference, etc. I always notice that higher end sportier cars have larger tires but never quite understood what the benefits were.
Thanks for sharing!
Old Mar 24, 2006 | 05:32 PM
Richard / E320's Avatar
2001 E320
Originally Posted by smazur
Also, while we're at it, can you explain what benefits I'd get by upgrading to a larger radius wheel/tire set? I'm assuming I'd get better ride and handling but why? Is it the sidewall, the larger circumference, etc. I always notice that higher end sportier cars have larger tires but never quite understood what the benefits were.Thanks for sharing!
Someone with more tire and wheel experience will weigh-in with a better explanation than me. A lower-profile tire has less flex because there is less side-wall height, so that improves handling. But because there is less side-wall and less air quantity, I don't think the ride actually improves. It probably diminishes the overall ride quality...
Old Mar 24, 2006 | 11:46 PM
djf1's Avatar
1997 E320
I'm pretty new to the MB world so I cant help with the offset question. One thing is for sure though, that going to 19's you are going to loose big time ride quality towards the stiffer side. Also one thing you always have to calculate is the weight. Unsprung weight is the worse enemy in performance and ride quality. 19" wheels most likely will be heavier unless they are high quality, but still a number worth investigation.
I dont see a real benefit in going to 19's, I would think that 18's should be kind of the limit with a very low profile 35-40 series tire. I'm planning to go to 17's with a 235/45 tire to improve a bit the handling and not penalize too much the ride.
On my 911, I "upgraded" for performance reasons to 18's from 17 inch wheels and for sure it has degrated the ride quality.
Finally the sizes you quoted I think they are very tall for your car. E320's optional tire on 19's is a 245/35 front and 275/30 series rear.
Old Mar 27, 2006 | 09:04 AM
smazur's Avatar
so it sounds like 17's are the way to go... A friend with another E class told me that 19's won't even fit in the space.
Old Mar 27, 2006 | 10:08 PM
okc329's Avatar
1997 E320 (silver/black)
18" should work
That's what came on E55's. Wider in rear of course. I put 17" AMG Monoblock II's on my '97 E320 and think that is a good size and look.
