Hazed up headlights
Rating: Thread Rating: 8 votes, 5.00 average.
Old Mar 24, 2006 | 06:12 PM
a08ynzz's Avatar
1997 E320
Hazed up headlights
Im looking for a way to clear up the haze on the headlights. I know i can buy new ones, but can these be cleaned? And if I were the get the zenon lights, would any one be interested in my orignal headlights?
Old Mar 24, 2006 | 09:14 PM
AMG_Fred's Avatar
Mercedes-Benz w124
Typically, lights only fog/milk/yellow updue to contamination found in the air. Just like you have to polish your paint, you have to polish your headlights. Just get any plastic polish found at your local autozone (meguiars PlasticX ) and apply the product with a cotton terry cloth and passionately ( not softly ) rub in the product, then wipe off. If you start to see results, then keep going! picture will help show if the damage is on the outside and not the inside....
Old Mar 25, 2006 | 01:27 AM
cragigotgame's Avatar
97 E420 90 300E
I looked around at the local parts stores for the plastic polish, when I had my old halogen headlights, but I never could find any so I bought a sandpaper kit used for refinishing plexiglass aquariums, and it helped a fair amount.
Old Mar 25, 2006 | 09:49 AM
Helmut430's Avatar
2020 S Cabriolet, 2014 SL63, 2002 SL500
the meguiars products really do work on the lens, but most stores dont carry them. I ordered the all of them on line at the Meguiars site
Old Mar 25, 2006 | 10:12 AM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
I regularly use Blue Magic on my Toyota's composite lamps - they are as good as new.
Old Mar 25, 2006 | 01:26 PM
AMG_Fred's Avatar
Mercedes-Benz w124
Craeful with that though. If you do that make sure you wetsand it and finish off with a rubbing compound and very fine grade of sandpaper, oh and use lots of water. If you want to go this route, go ahead, and just ask me how to do it. I'm really tired right now and am about to go to a golf course. But the plastic polish does not necessarily have to be a Meguiars brand. PlastX is good as well as the Mothers brand. And if not, you can just order online www.meguiars.com sorry but i was just born and raised meguiars. There may be better products out there but i just know that these work.
Old Mar 27, 2006 | 05:56 PM
rob_fed's Avatar
W204 C300 2010
If you cannot plastic polish, Flitz, Blue Magic or other metal polish used with a Mother's power ball will do the trick. I also used 1500 grit wet/sand paper before I start with the polish. Use lots of water, and use a microfiber cloth clean things up. The power ball is amazing.
Old Mar 27, 2006 | 06:26 PM
kudkudniyog's Avatar
2008 X164 GL450
Use Mother's aluminum polish. I works. I've been using it on all our cars/van with plastic lens.
Old Mar 28, 2006 | 02:28 AM
C-2's Avatar
C-2
98 E320
Just yesterday I was screwing around, poked around the garage and found a bottle of the Meguiars plastic polish...and my Makita buffer. Hit the lenses and ten minutes later, saw a huge difference. Then I found my Blue Magic, which seems to have a grittier consistency - but since I only had a finish wheel for the buffer, left them alone. When I get another foam cutting wheel, I plan to go to work on them again with the Blue Magic.
Looking at the chiny new lenses motivated me enough to go out and get some Silverstars. Popped them in and again, said wow, what a difference.
Huge and cool update for less than fiddy dollars!
The Wax Shop also makes a great product called "Safe Cut" - it works wonders on your paint and plastic.
Old Mar 28, 2006 | 05:30 AM
yoram611's Avatar
E320 2003 silver color
look at ebay item # 8049493497
they have a headlight cleaner polish renewer restorer.
this should take care of your problem.
Old Mar 28, 2006 | 12:42 PM
raymond g-'s Avatar
99 E320
that reminds me....zam must have taken a vacation or forgotten about us.
he was going to do a brief write up on his experience with this polisher....
clink
Old Mar 29, 2006 | 07:10 PM
StapleGun's Avatar
Originally Posted by raffy08
there are lots of cleaners available in the market that you can use to clean your headlights. i also heard some do wet sandding. or you can simply replace your headlights with a new one if you have a budget.
The whole point is to not spend money on a NEW lamp, they ain't cheap!
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
