Transmission flush procedure question
Old Mar 28, 2006 | 08:57 AM
Franasia's Avatar
2000 E 320S4 210.282 4Matic Estate
Hi everyone,
Have appointment with indie mechanic for tranny flush next week. They told me it takes 12 liters of DB fluid to do it. Sounds good to me so far.
My question is: at what point in the flushing process should the filter be replaced? Should they flush, drain, replace filter and then top off? Or should they drain, replace filter and then flush?
Cheers.
Old Mar 28, 2006 | 09:02 AM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Originally Posted by Franasia
Hi everyone,
Cheers.
That depends on your miles - if it's over 80K I would replace filter too..if they drain it, do it now regardless of miles. Typically, flushing does not involve removing the pan. They hook up a flush machine to the trans coolant lines and it recirculates the old out and the new in on a 1:1 ratio. Again, the pan is NOT removed for a flush.
