Any watchouts/advice for replacing bushings?
Old Apr 4, 2006 | 09:42 PM
Bill-Sims's Avatar
2010 E350 Luxury with Sport wheels
My front lower control arm bushings are shot, and I've ordered 2 kits. Any special watch-outs or advice from someone who has done this job on a 210?
I've done it on other cars that had bronze bushings at the lower control arm, but haven't done the job on the MB and its rubber bushings before.
I have a press and most equipment a dealer would have available.
Old Apr 5, 2006 | 11:28 PM
Ala-benz's Avatar
'00 E430, '83 Porsche 928S
If you have the tool to install the one-piece bushing you will be way ahead. I have seen it on ebay before. I changed mine myself and the job was a PITA without that tool. Once you see the new bushings, you will have a good idea of how the old ones come out.
I used an H-frame press to push in the one-piece bushing. The two-piece bushing can be pressed in using a large vise.
Old Apr 5, 2006 | 11:41 PM
E55Cent's Avatar
AMG 55, 335i, Mini Cooper S
While your at it you should change the ball joints also. I just ordered upper and lower complete control arms. I"m also replacing the tie rods. I'm doing this because I never want to do this again. You might want to check your uppers because mine are shot just like the lowers.
Mario
