Brake rotors
2013 E-350 4matic
Brake rotors
I want to change my brake rotors to cross drilled ones. DO I need to get new pads or anything else needed besides just changing the rotor? I dont want to change the size of it just the cross drilled stock size if possible. I have a 2001 E320. I will be painting the calipers silver when I change the rotors.
Thanks. AA
Thanks. AA
97 E420 90 300E
I dont believe it is 100% required, but recommended that you put new pads on when changing rotors. Somthing about them breaking in together. I put on new pads about a month before my new crossdrilled rotors and they were fine.
2013 E-350 4matic
OK Im asking because I just changed my pads less than 2 months ago so I didnt want to buy new pads again. But OK Thanks.
Whats better, drilled or slotted or Both?
I just picked up brembo replacement rotors,,new Porterfield R4S,braided lines,,and gonna paint them yellow.I saw on tirerack that drilled/slotted are not warrantied against warping.SO I would go with drilled,,,less pad wear I imagine.Good luck.
2015 Focus ST
i ordered powerslott slotted rotors of tirerack....definatle improvement with less brake fade and no warping.
