Cavity Wax
Old May 24, 2006 | 01:09 AM
michakaveli's Avatar
E300
Cavity Wax
What is this TSB and what does it entail?
Old May 24, 2006 | 01:14 AM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
Waxing the door frame under the seal to (hopefully) prevent rust.
Old May 24, 2006 | 08:33 PM
E300
I'm assuming this means removing the rubber seal around each door, spraying some goodness, curing and then reinstalling the seal?
Old May 24, 2006 | 09:42 PM
lexrex's Avatar
Don't know much...
See this:
https://mbworld.org/forums/e-class-w210/121331-w210-recalls.html
Old May 26, 2006 | 12:32 AM
Thrillhouse's Avatar
nah you have to take the LONG black panel under the side skirt on each side of the car off, and under those there is 5 or 6 holes that lead into the boxed part of the "frame" of the door sills and you spray wax in there to prevent rust..... more or less for places with "winter" ive only done one of these here in cali, dont see em much
Old May 26, 2006 | 12:47 AM
E300
so it's the rocker panels?
