Vacuum Lines Location
Old May 28, 2006 | 05:18 PM
BostonC4S's Avatar
'96 E320; 170K miles with extensive rust!
Can someone please list the location in the engine bay of some of the vacuum lines for the inline-6 3.2L engine? I would like to use seafoam to clean the engine which is inserted into one of the vacuum line. I tried using the brake booster line, but I couldn't remove the hard hose.
Old May 28, 2006 | 06:15 PM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
Believe there are some under the black spark plug cover on the top of the motor. I'd be interested to know if your O2 sensors survive this... Report back!
Old May 28, 2006 | 10:02 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Have a look under the Intake manifold and remove the plastic cover at the front of the cylinder head ...couple there
Old May 29, 2006 | 12:27 AM
Mr. B's Avatar
'97 E320
E-Class Tech Info
