LONG-TERM STORAGE Information Needed
Old Jun 2, 2006 | 03:19 AM
johnny's E320's Avatar
1998 E320 Sedan
Exclamation LONG-TERM STORAGE Information Needed
I have a 1998 E320. I am going to be abroad for over 10 months. My MBZ is parked indoors. I need "experienced" and/or "knowledgable" information regarding how to properly prepare your vehicle for long-term storage.
Weather Summer: 80-105 degrees F
Air: Very Dry
Weather Winter: 0-38 degrees F
Air: dry with occasional rainfall
Never snows and only reaches freezing point about 10-15 days out of the year.
Thank you for all your help!!
Johnny
Old Jun 2, 2006 | 08:33 AM
RobertG's Avatar
things with and without wheels
Fill the fuel tank and add fuel stabilizer.
disconnect the battery and put the battery on a float charger.
plug the intake and exhaust with a ragg
put he vehicle on jackstands and let the air out of the tires.
make a check list so you will remember what was done and undo it ,also change the engine oil when you come back.I hope this helps and good luck.
Old Jun 2, 2006 | 09:33 AM
ClayJ's Avatar
ON PROBATION
Robert's list isn't bad; but do a thread search for a complete discussion -- this has been discussed here on the forums many times.
Old Jun 2, 2006 | 01:40 PM
1998 E320 Sedan
Is there a reason why the air filter is not sufficient to plug the air intake?? Its not like it has a carb.
Old Jun 2, 2006 | 03:34 PM
RobertG's Avatar
Reason for plugging the air intake is to prevent moisture entering the engine or the intake.
