MAF failure symptoms?
Old Jun 7, 2006 | 11:53 AM
Craig Ewing's Avatar
‘11 C300 ‘11 C350
99' E 320 85k miles
Runs fine, has stalled at stop signs but restarted OK, and has cranked but wouldn't start, waited half hour, started right up.
Check Engine Light not on.
Thanks for any help
Old Jun 7, 2006 | 04:05 PM
galleryvw's Avatar
1997 E420, 1983 300D
if you have a local indy mercedes mechanic, i'd have them run the codes. even if the check engine light doesn't trip, you're computer is gathering codes everytime something wrong happens. autozone can run codes, but i doubt they would be much help in identifying the problem, as the codes are often vague and involve multiple parts at a time.
Old Jun 7, 2006 | 08:57 PM
black-e's Avatar
09 E63
Originally Posted by Craig Ewing
99' E 320 85k miles
Thanks for any help
I just had my crank position sensor replaced. It might also be called a fly wheel sensor. I had the exact symptoms. If that's it, an independent shop will be able to read the codes to confirm.
Old Jun 7, 2006 | 09:09 PM
Thrillhouse's Avatar
there prolly wont be any codes with those symptoms, more than likely your crank sensor, I say buy on and put it in urself, if that doesnt work your only out like 30 bux, if it does work you save yourself a lot on having someone diagnose it for u
Old Jun 8, 2006 | 06:55 PM
‘11 C300 ‘11 C350
Smile Thank you both
Black-e and Thrillhouse, you nailed it.
Thanks, Craig
