MAF Sensor? Try this........
Old Jun 12, 2006 | 05:09 PM
jman7000's Avatar
2011 E350
I have a 2001 E320 4Matic and recently my Check Engine Light came on. After some research, I realized it was the MAF Sensor and it could be an easy DIY project. After searching Ebay for the part, I stumbled across this little gem;
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Seems you can buy the Bosch Insert only for somewhere around $100. No reason to spend 200 bucks on the whole assembly. I got the sensor only and installed it my current housing in 5 minutes. No more Check Engine light.
Go to that link and then go to the Sellers store. They usually have 1 or 2 up for bidding.
Please understand I am not a mechanic so make sure that you verify that this item will work with your year and model. The listing will state the year and model it applies to. It worked for me.
Good Luck and happy bidding......
Old Jun 13, 2006 | 01:23 PM
Air Marshall Eldritch's Avatar
John Deere
Hey, good catch! I didn't know they sold just the insert. This highlights the the insult that $60 to $130 of the whole part (depending on the source) is pure 50 cents worth of plastic tube.
Old Jun 14, 2006 | 07:27 AM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Thumbs up jman7000
Thank you very much! The same one will fit mine too
M
Old Jun 14, 2006 | 09:55 AM
jman7000's Avatar
2011 E350
One more thing....you will need a tamper proof Torx screwdriver or ratchet set. The torx screws that need to be removed have a pin in the center (at least it did on mine), hence the tamper proof moniker. Purchased a set at AutoZone for 2.99.
Old Jun 14, 2006 | 10:17 AM
John Deere
By the way, you can make a tamper-proof torx screw into a regular one by inserting a small flathead screwdriver into the torx gap and snapping off the little pin at the bottom with a twist of the hand. Then use regular torx to unscrew.
