Aux Cooling Fans!
Old Jun 23, 2006 | 06:10 PM
risque1's Avatar
99 E320 wagon, 87 560sl.
Question Aux Cooling Fans!
Does anyone know the procedure on removing the two cooling fans in front of the radiator?
Old Jun 24, 2006 | 12:41 AM
horse's Avatar
96 e 320
I have a straight six but providing the radiator and fan setup is the same it is quite easy ,remove the plastic grille by rotating the two philip head plastic clips on top 90 degrees undo and place the power steering cooler to the side then remove the horn and centre support take the clips that lock the radiator in off then take out the four six mm screws out of the top crossmember that holds the bonnet lock and place it on the engine disconnect the fan wiring and from memory the fans will pull out,if you are doing it to replace the drive belt i have replaced mine a few times and have found if you elongate the holes in the driven fan so you can put alittle more tension on the belt they seem to last alittle longer.
hope this makes sense and helps.
