How to change shift knob?
Then pull straight up on the shift knob and it should come up. Do not try to turn the knob itself, there is a flat spot on the shift rod to keep the knob from rotating. If you force it to turn you'll damage the plastic key inside the knob (should you ever want to use the old shift knob again).
If you're replacing it with a new knob keep in mind that you'll also need to purchace the stick-on emblem.
By the way sliding the new knob on isn't for the weak, it'll take a very strong hand to push a new shift knob into place.
I see some interesting burl wood knobs on ebay for around $50, then I see some nice ones on Oberclasse.com for 80-120, then the dealer's offering at like $150.
Is a burl a burl, or are these price differences justified?
