Rear air vent not working...
Old Aug 4, 2006 | 06:02 PM
vernon97e420's Avatar
1997 E420
My rear air vent is not working. The vent in the console facing the rear seats. For some reason no air seems to blow out of it, even when the fan is on high. Has anyone else experienced this problem?
Any help in this matter would be greatly appreciated.
TIA, Vern
Old Aug 4, 2006 | 06:16 PM
ruffrob's Avatar
2010 Charcoal Grey E350 Coupe
What happens when you try to adjust the open/close thumbwheel near the vent??
Old Aug 6, 2006 | 10:06 AM
1997 E420
When I roll the thumbwheel back and forth nothing happens. Still no air.
Old Aug 6, 2006 | 10:27 AM
45acp's Avatar
BMW
if you have vents in your lower console, make sure that vent is turned on as well.
Old Aug 6, 2006 | 09:15 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Remove the carpet panels on the center console to inspect to see (IF) the vent tubes are hooked up.....if not remove the Center console to inspect the vent tubes
Old Aug 7, 2006 | 12:23 PM
KADE's Avatar
year 2000 model E-320 210 chassis
If you have vents inside your center arm rest you have to make sure those are turned to the closed/off position or you will get no flow from the back. Even after closing mine the air flow is still poor! just a one of the flaw of MB I guess .
