Rearview mirror, help
In the photo posted above, I can see that the right side retainer for the two clips is broken.
Both of mine are broken, so the clips are now useless. And Krazy glue didn't help either. I need to get a new front cover (that holds the mirror) with good retainers.
I figure I put my solution up here just in case others may benefit from it.
Ok, so I found out that the clips are originally used to hold the mirror (and housing) to the bracket (which in turn mounts to the ceiling pieces by the ball joint).
There are (in my case, were) plastic retainers that the clips mounts to. Those retainers break easily as also shown in the photos above.
So, I decided to mount the mirror to the bracket using velcros (Scotch Recolsable Fasteners P/N RF9731 http://www.doityourself.com/invt/u514784).
Check out the photos for the locations of the velcros.
Sorry about the low-res photos. The only camera I have at the moment is a cellphone.
Anyhow, hope this is helpful...
Don't feel bad about posting up the problem and solution - the next person to come across this problem can learn from you.
