will they fit
Old Oct 5, 2006 | 01:46 AM
rastapopolus's Avatar
will they fit
hello, i am new to this site but hope to stay. anyway i have a 1997 e-420 some is selling me a nice set of rims but the tires on them are 235/50/18 will they fit? i went online and a calculator said it was almost 8% more daimeter and they recomend not more than 3%, please help, I want to negotiate a better price if i need to buy new tires. thanks
Old Oct 5, 2006 | 02:22 AM
raymond g-'s Avatar
99 E320
chance are good that they will rub. to what degree will depend on the tire
profile, your suspension set up, and the offset of the rims.
Old Oct 5, 2006 | 10:28 AM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Is The car lowered? I Have the AMG E55 Monoblocks with 245/45/18 on the front and My Wagon IS Lowered..No Rub So 50 Series may Not rub on a Non lowered car?
Old Oct 5, 2006 | 10:41 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Buy new tires! That 235/50 is too tall and that 8% difference is way to much. Ideally you should be running a 235/40/18. You may be able to run a 245/40/18 depending on offset and width, etc. May need to roll fenders.
Also, if the tires are 235/50/18 what car did they come off? The rims may not be for a W210 with wrong offset or use wrong size bolts.
Old Oct 5, 2006 | 12:17 PM
the rims are mandrus, i think they are made for mercedes, 5 x 112 bolt pattern 18 x 8.5 with 32mm offset, more insites wil be appreciated.
Old Oct 5, 2006 | 12:47 PM
E55 KEV's Avatar
Veteran: Air Force
http://www.mandruswheels.com/
Sounds like the rims will fit. Make sure you get/use the correct lug bolts. Your OEM bolts have a Ball or Radius seat and those Mandrus, made by TSW, maybe Cone seat.
Old Oct 5, 2006 | 04:14 PM
Air Marshall Eldritch's Avatar
John Deere
On that note, can someone give me a quick primer on what offset figures will fit a 210 that is slightly lowered?
