EC light A/C control stays on - Help!
Old Oct 17, 2006 | 04:25 PM
JYO's Avatar
JYO
1999 E 320 (sold), 2015 AUdi S5 (sold) 2005 CLK55 Cab, 2016 Honda Pilot Elite, 2011 Jaguar XF
My compressor is not coming on and th eonly moe it stays on is the economy mode. My brief research has found that it may be a bad sensor.
Any thoughts what I should do now? Thanks
a/c was blowing very cold air just prior to this happeneing.
1999 e320
Old Oct 18, 2006 | 11:19 AM
okc329's Avatar
1997 E320 (silver/black)
A couple of possibilities:
1) The evaporator temperature sensor on these cars is prone to failure. Check this thread for this.
2) Symptom you have will also appear if the A/C system is low on refrigerant, e.g., a leak.
There is a pretty good set of diagnostics that can be run via the contol panel to help identify the problem. probably something in the W210 thread about those also.
Old Oct 18, 2006 | 11:39 AM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Cool Diagnostics
Correct about the diagnostics. Try the search feature, or look for threads about W210 A/C problems. I was having trouble with mine in May-June 2006 (if you want to look by date).
One member here wrote a program that you can use to plug in several of the numerical values obtained when you "ask" the car for them. It will then diagnose most of the common problems.
Good Luck!
Old Oct 19, 2006 | 07:44 AM
Peter Guenther's Avatar
92 500sel/01 320e wag
AC diagnostics
Check this link from Continental
http://www.continentalimports.com/ser_ic40142.html
