Interior Light Timer?
Would this most likely be a door switch or the timer?
Thanks -
John
ball at the end of the switch and see what the result is. if light turns off quicker
then it seems to point to a switch adjust.
Thanks a lot for the reply!
I fixed it, at least temporarily. I pushed the driver door switch in and out by hand, which didn't fix it. Then I did the same with one of the rear door switches, and it seemed to start working again.
So probably a sticking (or mis-adjusted) switch. Thanks again.
John
