battery
Old Oct 29, 2006 | 10:35 AM
sts15's Avatar
2015 E350 4matic Sport and 2011 C300 4matic sport
battery
Is there a way to tell if it is time to get a new battery, short of waitng for the battery to be dead one morning? I have had my 2001 for over two years, and i am sure the battery was not new when I bought it, could be the original. I do not want to wake up one cold morning and have a dead battery but I don't want to replace it if it is still good. Thanks.
Old Oct 29, 2006 | 11:41 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Batteries generally last 4 to 5 tears. Be proactive and replace it at the 4 year mark. That should minimize the chances of getting caught with a dead one.
Old Oct 29, 2006 | 09:27 PM
E430_4MATIC's Avatar
1973 280SEL 4.5; 2021 E450S4 Wagon
I still have the original battery in my 2000 E430 4Matic.
Old Oct 29, 2006 | 09:31 PM
livetodrive's Avatar
2001 E-430 4-Matic
I also have the original battery in my 2001 E430 4-Matic.
Old Oct 29, 2006 | 10:40 PM
ProV1's Avatar
MB, BMW
since you drive a MB, just call up roadside assistance wherever you are if your battery dies. they'll come to you 24/7 and replace the battery.
Old Oct 29, 2006 | 11:15 PM
raymond g-'s Avatar
99 E320
you can preview and gauge the health by...
- performing specific gravity test using a hygrometer ( $5-20 at auto supply)
- checking the voltage under load (large drop indicates inability to hold charge)
- check voltage regulator/alternator in good health
- ensuring fluid level is replenished (distilled water)
- keeping battery charged so that it doesn't sulfate and short between cells
- get a trickle charger and try to avoid deep discharge as a result of leaving
lights on, etc. trickle back to full charge after replenishing water
if you do this regularly enough, say, every several months, you can really
extend life of your avg lead acid battery by years....well beyond 5 yrs
Old Oct 30, 2006 | 01:22 AM
cerritos's Avatar
I had an unfortunate incidence on Friday night that my battery is completely discharged. What should I do to help it to recover? I've been charging it for one and half days now. It still drains 3.5 amps from the charger. (down from 8 amps)
If I keep charging it will it go down to 0 amp? When is the best time to stop charging?
What does a trickle charger do? Should I use a trickle charger now?
Old Oct 30, 2006 | 02:48 AM
raymond g-'s Avatar
99 E320
what was the load which caused the discharge?
when you say complete, how did you measure 'complete'?
did you check battery fluid level and top off prior to charging?
did you check specific gravity?
Old Oct 30, 2006 | 09:35 AM
E320Star's Avatar
2000 E320 Sedan
Mine a 2000 the original went out in Aug 2006. Thsu lasting 6 yrs. I recommend next yr when u take th car for an oil change, have them inpect the battery.
Old Oct 30, 2006 | 07:22 PM
ccmbduong's Avatar
Battery would die without giving any warning, so change it every 5-6 years depending on type of battery that you are currently using. I use the interstate battery and it seems to work very well so far... I remember it as MTP-3 or MPT-3
Old Oct 31, 2006 | 02:59 PM
lkchris's Avatar
'10 CL550, '12 GL550
Just know that because your battery lives under the rear seat, it must either be completely sealed or have provision to vent gasses out a hose.
Otherwise, sulphuric acid fumes will corrode things under your seat and you could possibly have a hydrogen gas build up.
Get an OE battery from your dealer.
Old Oct 31, 2006 | 09:49 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Good question here I think. Some of us remember the "good old days" when our batteries started to sound weak before they failed. I have not had trouble with my MB, but I think I'm now on my 4th battery on my 1994 Plymouth Acclaim. Every time it went bad, it was completely without warning. They might now be "maintenance-free", but I long for the days when we could more easily check the water level and specific gravity with a hygrometer.
Old Nov 1, 2006 | 09:52 AM
E320Star's Avatar
2000 E320 Sedan
U would think they do things better now !!
Old Nov 3, 2006 | 03:10 PM
sts15's Avatar
battery
AS I am mechanically challenged I have never even looked to see where the battery is. I will start by looking at it. As the weather in NJ has hit the 30's today, I may find out sooner than later that the battery life is about over. Thanks for the advice
Old Nov 10, 2006 | 02:43 PM
spoothead's Avatar
2000 E430
Don't forget you can call Mercedes roadside assistance and they will come out and replace the battery for you with a OEM Mercedes battery. Our total was $162 but it was worth it to avoid the hassle. Took about 30 min and he reset power windows, seats, etc. I told them the car was cranking longer than usual and I was afraid the battery was dying. They came in about 1 hour. Not too bad.
Old Nov 10, 2006 | 04:48 PM
ProV1's Avatar
MB, BMW
list price on the OEM battery is less than $130. roadside doesn't charge labor for battery installations, you got hosed...
