Correct way to remove spark plugs on M119 engine?
Old Nov 16, 2006 | 04:43 PM
ProV1's Avatar
MB, BMW
I thought i'd ask before I mess it up. after taking the black plastic cover and the small bolts that hold the connector down, do i simply lift up the connectors and twist the spark plugs out? is there a special procedure or trick I need to know. thanks
Old Nov 17, 2006 | 03:15 PM
smazur's Avatar
Once you get the black plastic cap off the head that covers the plugs, just wiggle and pull the rubber plug connectors, they'll come off fairly easily...
Your socket extender needs to be about 9-12 inches long, make sure you have this length before you get started...
Unscrew the spark plus and replace one at a time so that you don't cross and/or confuse the connector wires.
