MAF cleaning tips
Old Dec 21, 2006 | 10:01 AM
ReZzZ320's Avatar
MAF cleaning tips
hey guys
has anyone ever cleaned the MAF sensors of their W210?? If yes could someone tell me how is this done??
Old Dec 21, 2006 | 10:03 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Buy a can of CRC Mass Air Sensor cleaner at Pep Boys...like $7.00
Old Dec 21, 2006 | 10:26 AM
ReZzZ320's Avatar
no Pep Boys in this part of the world lol
but seriously will it cause any damage to the MAF sensors coz ppl have told me to NOT clean it
Old Dec 21, 2006 | 10:36 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
MAF's are not designed to be cleaned. They are throw away consumables. The MAF is extremely delicate and cleaning is likely to destroy it. Let it alone until it fails and then replace it.
Old Dec 21, 2006 | 10:37 AM
C43AMG's Avatar
Veteran: Army
The people that told you NOT to clean it - are these the same people that want to sell you a new one.I've used it on my vehicles , I wouldn't recommend anything to anyone if I haven't tried it myself.
Old Dec 21, 2006 | 11:45 AM
martz's Avatar
German
From another MB Forum
Removed the MAS from the intake. Then i sprayed it down using basically the entire can of carb cleaner and the entire can of brake cleaner and then a lil of the electronic cleaner. (brake and carb cleaner was like $5 total) after that I just reinstalled the MAS and turned on my car, let it idle for a bit, then took it around the block
Old Dec 21, 2006 | 12:40 PM
Bossman123's Avatar
2001 e320 2004 e55
It doesn't hurt the MAF to clean it. It is delicate but not so much that cleaning it with electric contact cleaner will damage it. Remember it is used to having air rushing over it for years! Use a cleaner that leaves no residue. Very important. You will also need a hex key with a star punch (hole in the tip) to completely remove the maf from the housing. If your maf is going bad, take it out and clean it, its going bad anyways. There's a good chance cleaning it will get another 30,000 miles out of it. Make sure and clean the wires in the tip of the MAF as well as the two at the base. Let it dry, put it back in and run your car around town for an hour. If the car starts running good, great! If not, then go buy another one. 300 bucks from dealer. The insert can be found on ebay for a hundred but buyer beware.
