need help on new rims
Old Sep 16, 2002 | 02:15 AM
dallasdriver's Avatar
99 e430 Green
Need help on new rims. I know BMWs not Benzs I know nothing about wheels for my new w210, 99 e430. Would 18 inch BBS rk 2's with an offset of et32 and a 5 by 112 lug pattern work? I need to know what will work if these won't. I have cords showing on my frount tires and I want a stifer sidewall than a 16, last owner did not rotate tires, but the car is in great shape with only 13k, and it was below whole sale which leaves me money to put on some new wheels and tires.
Old Sep 16, 2002 | 02:31 AM
Firenza's Avatar
E350
Yes, the BBS RK-II 18x8.5 ET-32 can be install for E-Class (w210).
But make sure that the center bore is 66.5. Cause both 5x112 can be fitted for Mercedes and Audi, but they have different center bore. Or else you might need the center-rings !!
Old Sep 16, 2002 | 04:45 PM
AJChenMPH's Avatar
2008 Subaru Legacy GT Limited
You may want to consider 17" rims if the roads in your area aren't so hot. Even with 17" rims, you're running a tire with a 45 aspect ratio, so the sidewall will still be shorter than the 55 ratio you run on 16" rims.
