Picked up the car, have some issues
96 and 08 911 turbos
1. The bulb in the climate control burned out. dealer wanted 80 to replace, I will get the tools, and fix it myself. What type of bulb do I need?
2. Command system does not recognize that the cd changer has a magazine in it. The magazine also will not eject. Dealer says changer is toast, quoted 800 for a replacement.
3. Squeaky steering wheel when moving slightly off center. Annoying, but I've heard its steering rack related at a lovely 2700 a pop. I'll live with this if there is no easy fix.
4. C pillar interior panel loose on drivers side. The clips won't lock into place. Do I need a new panel, or just some new clips? Any other help here?
So far, not quite what I expected...
Ok, fixed number 4 and the sunshade
The C panel metal clip was bent so it wouldn't hit its metal cousin on the body. After some struggling, I decided to bend the metal clip back with some locking pliers. 5 minutes later and its snug.
The sunshade just required a little tugging, and now it works fine if you do it slowly. Sticky roller is all I believe.
It seems nobody stocks the climate control tools, which sucks, but I can get them cheap online.
Now If there were some easy fix for the steering id be good.
Oh, and the cd player I have is the Mc3198. Is that correct for this model?
2001 e320 2004 e55
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
My mechanic sprayed some lubricant in the steering columm area and it cleared mine up. I believe it's a boot that drys out and needs lubricating. There are a lot of threads on this topic. i.e. Squeeky steering wheel.
You will find that there is always something going on with your MB to annoy you. Once you get it fixed, another will come up. Its the nature of the car. You get used to it. I still wouldn't own any other car....except the ones that I can't afford. : )
The CD changer is bs, and I sent the seller an email about it. We'll see what happens.
The display problems im having now are also bs.
