Need Help Removing 3rd Brake Light '97 E320
Old Sep 19, 2002 | 08:20 AM
C230Ken's Avatar
Hi,
The rubber gasket on the 3rd brake light has gotten pretty dirty and I would like to replace it. How can I remove the brake light assembly to get it off?? I've tried from the top and can remove the back to get to the bulb and tried the squeezing the clips in the trunk, but it won't budge - any ideas???
Thanks,
Old Mar 7, 2005 | 03:10 AM
BenzVince's Avatar
09' E350, 01' Maxima SE, 93 Nissan Maxima SE, 1987 Nissan Maxima SE
It's not hard to remove it, you'll see a plastic squarish tab on each side, you have to squeeze it with your fingers and pull it back and it slides out towards you.
