Hey
Old Jan 29, 2007 | 01:13 AM
Z06EATER's Avatar
1997 C36AMG
Hey
hey guys i wanted to know sumting. i have a e420, and when i start this puppy up when it's cold and the radio volume is low, i hear like this whining noise, and it get's even more high pitch with the Rpm of the engine. wanted to know what's goin on there. thansk!
Old Jan 29, 2007 | 04:59 PM
gujupimpster89@'s Avatar
97 e420
ya same thing happens to mine, but after the car is warmed up it will go away, i kinda like it though makes it seem like a have a supercharger, LOL.
Old Jan 29, 2007 | 05:05 PM
vb26's Avatar
Velvet Fleetwood
timing belt
Old Jan 29, 2007 | 05:50 PM
hubert's Avatar
14'G63 AMG ,1994 Mercedes E500, 2020 Range Rover HST
Its the secondary air pump
Old Jan 29, 2007 | 09:50 PM
Z06EATER's Avatar
1997 C36AMG
Talking Lol
yes indeed it does sound like a supercharger, once i revved it, and it sounded pretty sweet. well anyway, is there any way to get rid of this noise? if not it's kool. btu i wanted to know. thanks for all the replies guys. it's heart warming to know we can all help eachother out!
Old Jan 29, 2007 | 09:52 PM
Z06EATER's Avatar
1997 C36AMG
Oh
one more thing! i have just installed a 420 watt amp in my e420, and i left everythign stock i just added one 12 for more bass, sounds awesome, but i had a question. u guys reccomend me getting a capacitor, so i don't strain the electtical system on the car, at night, not much, u gotta really pay attention to notice, and interior lights kinda dim when the bass, hits, but the head light, and all other exterior light sstay strong, tell me what u guys think! thansk guys!
Old Jan 29, 2007 | 09:58 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Originally Posted by vb26
timing belt
MB has no timing belt. They use a chain.
Old Jan 29, 2007 | 10:06 PM
ZedStyle's Avatar
Youngtimer
your new sound system is not grounded properly, what you're hearing is interference from the alternator. if you start the car and you hear the whining, turn the radio off, and it will go away... that will mean it's DEFINITELY your system.
it's arguable how much capacitors help, but in my personal experience, it helped with the lights dimming and also it DOES cut down the whine a little bit. i disconnected it, and now can't listen to the system because the whine is so bad.
a real fix is a newer/better battery like an optima, and a bigger alternator. i would try to make sure that the system is grounded properly and put a capacitor in there and see if it helps, that would be the easier fix.
also, make sure your power cables are not running next to your speaker wires, ideally they should be on opposite sides of the car.
i'm speaking from personal experience, i ran my power wire with my speaker wire, and didn't ground the head unit properly, and now i have the terrible whine. like i said, when i had the cap attached, the whine was significantly less than it is now.
Old Jan 30, 2007 | 09:09 PM
mulletskid's Avatar
2000 w210
What about a noise suppressor (coil) in series on the positive wire? If in fact it is engine noise.
Old Jan 30, 2007 | 09:31 PM
KINGGLORY's Avatar
Thumbs up been there
This happens sometimes when new plugs or cheap wires were replaced. If thats not the case then I would suggest a in-line noise suppressor that goes on the hot wire.
