rear end sliding
I am all over the road with this car in the snow. I just added lbs of weight to the rear trunk. This helped some with traction but the tail must be really light.
I did have the switch in winter mode so the take offs are in 2nd gear.
I do have new tires as well. less then 30days old
Any Ideas ??
If you're in western Michigan, you can drive down to South Bend, IN and get a set of winter rims & snow tires from Tire Rack. Winter tires turn the W210 into a tank in snow.
Handling is compromised both in dry and snow when the drive wheels are also the wheels that steer, as is the case with FWD. In my experience, it's much easier to control a RWD car in an emergency sliding situation than a FWD car.
You can certainly get into more trouble with RWD (throttle-on oversteer) if you don't know what you're doing, but you also have much more leeway pulling out of a slide.
..and tires certainly mean a lot. I had softer Conti's on my last w210 which were much, much better in the snow due to the softer compound. My harder Pirelli's on the E320 are nice and all, but they ride rougher...though they have stiffer sidewalls that allow the car to handle better, next time I'm getting Conti all seasons...they do the job even in tough snow, and I think I'd rather have the quieter ride.
But any rear wheel drive car is not going to be the best in the snow. Unless you have the 4-matic or some kind of rear wheel car with all wheel drive. In Michigan I can only imagine how much snow you get!
