radio code e320 ?????
Old Mar 4, 2007 | 09:53 PM
mbz2001's Avatar
Question radio code e320 ?????
I disconnected my battery and after I reconnected it it requires a code for the radio. I put the code in and it needs it again 2 more times. After that it says WAIT and it comes back after ten minutes and says CODE again. I bought the car used and I'm not sure if the radio has been replaced. I have the code card that came in the glove box. The card has this S/N on it.
Serial number is
BE 6003 1 1040787
Can someone help me? thanks....
Old Mar 4, 2007 | 09:58 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Check and see if the s/n matches the unit, if not good luck!! Dealer should have the code from your VIN if its the correct Command unit
Old Mar 4, 2007 | 10:02 PM
mbz2001's Avatar
How do you check the S/N? Does the radio have to be pulled out. what tools do I need to do this?..it's not the comand unit. thanks.
Old Mar 4, 2007 | 11:04 PM
raymond g-'s Avatar
99 E320
radio removal key
variation-on-a-theme
Old Mar 4, 2007 | 11:09 PM
hubert's Avatar
14'G63 AMG ,1994 Mercedes E500, 2020 Range Rover HST
http://cgi.ebay.com/ebaymotors/GENUI...spagenameZWDVW
Old Mar 5, 2007 | 12:01 AM
mbz2001's Avatar
thanks guys!
