Console of 1997 E420
Old Mar 9, 2007 | 11:48 AM
citruspilot's Avatar
06 CLS500, 04 Tahoe, 04 Infiniti G35 Sedan, Boeing 737
Lightbulb Console of 1997 E420
Have a quick question. I am replacing my 420's console window/mirror switch unit. How does the gear shift knob come off and wood trim lift out so I can replace same? What kind of tools etc........
Thanks.
Jeff
Old Mar 9, 2007 | 12:18 PM
raymond g-'s Avatar
99 E320
dont know for sure re 97 but likely that you....
- place palm directly over knob.
- with thumb and index finger extended downwards, grab the circular collar
directly beneath the knob and twist clockwise. click. pull knob off
- lower cupholder lid
- grasp wood trim edge closest to cupholder and lift up
- shift surround is seperate piece and pops up at same time
- oh...forgot i posted video on this...
Old Mar 9, 2007 | 12:23 PM
Man, that video makes this look really easy. From the looks of it I dont even have to take the shift knob off afterall. Raymond, You are a true GOD!!!
Going to get the part now.............should be in by afternoon!!
Thanks.
Jeff
Old Mar 9, 2007 | 04:10 PM
Its just past 4:00 PM. I got the part installed in 10 minutes after I got home! That included cleaning the console of spilled coffee and coke from the past 10 years too. Once again, thanks for the tip.
Jeff
Old Mar 10, 2007 | 12:07 PM
galleryvw's Avatar
1997 E420, 1983 300D
nothing to it- just pry the black plastic trim that surrounds the shift unit. you can probably just get a fingernail under it. then the whole wood peice also pries up - it's easiest to get your fingers under it by way of the front by the ashtray. just pull steady and slow, the clips will release. all the window switches are connected underneath the wood. they release by sliding a little brace forward. if you look at it you will figure it out. I think the mirror switch releases with just a hooking type clip. it's all very easy and requires no tools.
