Rattling, Shift Knob Issue
Old Mar 11, 2007 | 04:03 AM
lxl_Jeffro_lxl's Avatar
1987 E300 TD
So I'm going over this hill at about 40-45 mph, around 2,500 RPM's and I hear a rattling noise where my gear shifter is located. I hold the shift *** and wiggle it a little, then it stops! I've taken off the plate and looked but nothing seems to catch my eye. Does anyone else have this problem...or does anyone have any ideas what I should do to prevent it from making this rattling noise? Last Q, how does the shifter knob come off on a 1999 E300 TD? (Some POS transmission shop twisted it and jacked it up....I'm having them pay for the knob, but I want to install it)
Old Mar 11, 2007 | 12:15 PM
raymond g-'s Avatar
99 E320
try this....
- place palm directly over knob.
- with thumb and index finger extended downwards, grab the circular collar
directly beneath the knob and twist clockwise. click. pull knob off
Old Mar 12, 2007 | 04:23 AM
1987 E300 TD
When I turn it, it doesn't click, it just keeps turning.....and they stripped something I bet....anyother ideas?
Old Mar 13, 2007 | 02:10 AM
1987 E300 TD
I've taken off the cover to the center consol, and the cover over the gear shifter......and I look but nothing looks loose or out of place. Now the rattling is getting worse and makes a rubbing noise around 2,000 RPM
Old Mar 13, 2007 | 02:41 AM
Lancelot's Avatar
'01 W210 E320 CDI
Mine had the same problem and the shop said they only had to replace an o-ring. I have the knob that clicks-off btw...
Old Mar 13, 2007 | 02:50 AM
1987 E300 TD
Hum....it would be nice if I could find the broken o-ring because I don't want to spend $500 to have it done haha. Yeah like I said earlier someone messed up the shift knob so it wiggles easily and it won't click. I'll see what I can do thanks for the help!
Old Mar 13, 2007 | 11:24 AM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Its The Shift Rod Bushings there are two...... one at each end of the shift rod that goes between the transmission and the shifter...The Bushings wear out and will cause the problem....I have done LOTS of them....
The Bushings are a couple bucks each and the labor is 15/20 min....(IF) its on a hoist
