"No CD Changer"...grrrrr
Old Mar 26, 2007 | 12:06 AM
Yellow98Cobra's Avatar
2000 E430
So I got the error "No CD Changer". Well I tried holding the EJ button and I got it to reset. The changer will not eject the magazine nor will it play a CD or recognize I even have the changer. Anyone?
Old Mar 26, 2007 | 02:41 AM
raymond g-'s Avatar
99 E320
search this forum as well as Audio. this is an unfortunate ailment with the w210
changers....a byproduct of poorly designed changers. the drive mechanism rides
on 4 gell filled shock absorbers and the magazine carrier has a tendancy to
become misaligned. in addition, the connectivity issue is a frequently reported
snafu.
Old Mar 26, 2007 | 12:51 PM
Air Marshall Eldritch's Avatar
John Deere
This instance is worse than normal. Usually we get the No CD error which requires a reset, but I've never heard of No Changer. That's bad.
Old Mar 26, 2007 | 01:11 PM
2000 E430
Thumbs down
Yeah it still wont recognize the changer. I read one person who took out the radio fuse so that you would have to re-enter the radio code and that may get a reconnect to happen. Gonna try that and see what happens.
Old Mar 26, 2007 | 01:35 PM
LeftLane911's Avatar
1997 E320
Talking Errors
Fonzy used to just hit stuff and it would work, maybe give it a shot
ghaffar23's Avatar
'08 CL600 with 152k km; '01 E430 4Matic with 433k km; '17 Porsche Cayenne with 130k km
La Jolla Audio Repair...http://www.lajollaaudiorepair.com/lar.htm. They have a quick turnaround (~2 days), and they also have a 1 year warranty on their workmanship. I did mine and it is good as new. The guy, Cleeve, is a great guy. Knows his stuff. Tell him that ghaffar sent you. I actually found a link from raymond g-, so thanks ray! At $280 plus shipping, it's MUCH cheaper than getting a new unit from the dealer @ $1000.
Old Mar 26, 2007 | 03:03 PM
2000 E430
I dont think its the player that has gone bad. For some reason its not recognizing that there is a changer.
Old Mar 26, 2007 | 08:11 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
I had a problem with mine (bought used on eBay and installed incorrectly) - my car had never had one. The guy who installed mine did not program the car (or COMAND in my case I think) to look for the changer. If the D2B fiberoptic loop is not configured correctly, all sorts of strange things can happen, and not only to the CD changer.
I hope this is of some value,
Good Luck!
Old Mar 26, 2007 | 11:12 PM
raymond g-'s Avatar
99 E320
previously, i would recommend that you disconnect the - cable from the battery
for a few minutes. but given the fact that this may introduce a host of memory
setting issues which can throw folks, we'll try plan B....
pull the fuse and this will serve the same purpose, ie disrupt the power from
the head unit. hopefully this will cause the luggee to be expelled.
similarly (for me) this was the easiest as I have all thumbs as well as the
head unit removal keys in the toolbox: slide out the head unit and yank the
power cable.
how long to disrupt power? i dunno. i usually go up and brew a cup of coffee
and dink around on MBWorld and come back down to reconnect. hasn't failed
since.
....and avoids having to reset the windows, roof, seats etc if you disconnect
the NEG battery cable.
oh....be sure you have your radio access code at hand, which will be needed
if you cut power to the head unit.
if your car is equipped with (or had been previously) onboard phone, then
the D2B fiber loop may have been left 'open'. it should be a continuous
circuit/loop from head unit, to phone, to changer, and back to head unit.
one person mentioned pressing and holding one of the head unit keys to
'reset' something (hold for 30 secs) but i've not had firsthand experience
with this trick.
p.s. i have 1999 and 2000 E320 and do not have Command. the aforementioned
reflects this experience
