Blaupunkt Long Beach DVD35
Edit: I have 99 e320. I searched through this board. I seen the posts about getting the vw harness. I was hoping with the Blaupunkt hu I wouldnt have to worry about all of that. Im not worried about losing the changer options since tis a dvd player & I dont have steering wheel controls.
And yes, Blaupunkt is simply PnP.
You might able to dig out my post from last year about install Blaupunkt while I still have my W210.
https://mbworld.org/forums/showthrea...ight=converter
However, if you have Bose system, you will need voltage converter.
DVD35 and most after market HU has 4V of preamp power, which is much higher than Bose's 1 Volts input. (pro-long use will likely to kill your bose amp that also creats lots humming and clicking noise when turn on)
Install voltage converter is NOT hard and inexpensive as well.
