misfire
After replacing the motor in 97 E420 I got a misfire on 1-4 (right side only).
No codes are given besides a P070X Misfire
It is running rough on idle and up to 1200-1500 rpm and its absolutely fine on the road.
And I am simply out of clues ….
This what was done and checked on the car so far:
-Spark plugs
-Coils
-Injectors
-Impulse on coils and injectors
-Right cat converter
-Right CO sensor
-Compression in cylinders
-Vacuum lines
-Sensor adaptation is reset
not checked:
-Computer or harness (low possibility) -can not test.
-Timing (very low possibility) as at the best of my knowledge the motor was never taken apart. But I will check that tomorrow.
Please send all your suggestions. Thanks.
Intake cams were of timing.
Bouth sides back 2 teeth so when advenced it's actualy on mark.
Why did sombody changed the timing on this cams ???
must be a dumb son of a gun or somthing
Any way runs like a wind. nice and smoooothrrrrrrrrrthhhhhhhhh...
Ok, thanks pople!
You are to be commended, not for solving the problem, but for taking the time to post the answer. Most people ask for help, get answers, solve their problem, and go about their way without a thanks or any feedback. You are rare.
