Transmission problem?
BTW : I have no check engine lights.
Thank you in advance.
2. Since you said you replaced the motor mounts, this may also be the flange between the back of the tranny and the driveshaft. Jack up the car, put the auto in neutral and twist the driveshaft with your hand. If there is any play whatsoever, the rubber flange will need replacing.
3. Has the tranny fluid filter also been replaced everytime the fluid is replaced. This involves removing the bottom pan on the tranny and removing two small screws to replace the filter. The filter may be clogged.
-Jesse
See the fluid change artilce in DIY section of mercedesshop.com site.
Thanks for the help.
