Not another issue....
Old Apr 29, 2007 | 04:33 AM
MB>BMW's Avatar
G63 W463
Im driving home from a night out tonight and I try to use my cruise control. TO my surprise its not working at all. I tried ending it(maybe it was still on form beofre) and then resuming, nothing.
I just recently had an oil issue, and earilier before my way home, fog ligth went out(happens all the time and quickly fixed with a nice tap), and my bas/abs lights when on(fixed when car is restarted).
Whats going on, how do i get my cruise control back???
Old Apr 29, 2007 | 11:46 AM
OldNate's Avatar
1998 E320
If I remember correctly, bas asr light on, that will disable your cruise control. Did you try using the cruise before you restarted the car?
Old Apr 29, 2007 | 12:23 PM
illest's Avatar
w210 AMG or S213
I have the same issue but no bas asr light on.
Old Apr 29, 2007 | 04:39 PM
Lancelot's Avatar
'01 W210 E320 CDI
Are you running a tire/rim setup that's beyond spec?! This may cause ASR errors and/or cruise control disengaging...
Old Apr 29, 2007 | 05:07 PM
MB>BMW's Avatar
G63 W463
nope-riding all stock
the lights had come on while i was parking, but then i shut the car off, left for an hour or two, and then started her up, no bas,asr lights.
on the way home on the highway the cruise control wouldnt work.
Old May 1, 2007 | 04:55 AM
MB>BMW's Avatar
G63 W463
bump.
Old May 1, 2007 | 10:20 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
With the ABS/BAS failure its most likely a brake light switch bad. Minor fix. That also takes out the cruise.
Old May 1, 2007 | 06:18 PM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
Cruise won't work when your BAS/ESP is off, as indicated by your warning lights. Sounds like you have an evening to plan with the footwell replacing your brake light switch.
BTW: If the cruise stalk won't set when you tap it up, try tapping it down. It can still set that way if it's just a faulty stalk (like mine).
Old May 2, 2007 | 08:54 AM
sts15's Avatar
2015 E350 4matic Sport and 2011 C300 4matic sport
My BAS/ESP warning lights come on one every couple of weeks. As soon as I shut down and turn the car on again they go off and stay off for a while. I have never had a satisfactory answer about why this happens but has been happening for over a year. I do not know what triggers the warning lights to come on, and I do not know why what ever that fault is that it goes away...
Old May 2, 2007 | 10:12 AM
sosh's Avatar
The warning lights are there to tell you that you have a problem. The lights you are getting are for very important safety systems. Why are you ignoring these and compromising yours and others safety?? Your dealer with the Star system can tell you exactly what is causing this and correct it. Spend a few bucks and get the problem corrected before you have a major problem.
Old May 2, 2007 | 06:23 PM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
This is a critical safety component. Don't risk your life driving a car that is not equipped with BAS/ESP or that has a BAS/ESP malfunction. Have your car towed to the dealership to get those systems checked out right away. And sell all your vehicles that are (a) older than 1998 and (b) not Mercedes-Benz.
Old May 2, 2007 | 11:55 PM
MB>BMW's Avatar
G63 W463
crazy enough, these seems to have done the trick. Thanks for the quick tip. I didnt need to do this before. Is there something I did to cause this(i was pushing the stock back and fourth while the car was not on out of boredom) wither way, i got cruise back. Thanks everyone for your help.
