Parking Break
any idea how much the dealer ll charge to fix it?
swap that I can imagine is that the original lug bolts were too long when used
with the new rims, thereby extending and impinging on the parking brake. ??
also an update the guys in tirerack helpd me alot, they got the right size bolts, now i have all 4 new rims onwith correctt bolts. as for the parking brak i think it is the cable snaped, i checked the inside of the rear breaks and they were fine but the cable was loose.
thanks for the reply everyone.
no telling what you broke until you take it apart, but it's probably pretty ugly, if you drove the car at all. if you can't work on drum brake type systems, then i would estimate repair at 1 hr plus parts per side at a shop. hopefully, a hardware kit it sold separately. that's probably all it needs.
one more thing. make sure you keep the original lug bolts in the car, if you plan to use the original spare or your new lugs may be too short.
David
Its a set of Brake shoes insided the rear brake rotors...Very basic
