In pro lights
Old May 30, 2007 | 09:02 PM
43fatman's Avatar
2001 E430 Sport
In pro lights
I have a 2001 430 and want new headlights. Also have factory HIDs . Have seen Depo conversions with HiD any one done it with In Pro ones? Hell dose any one on hear have In pros?
Old May 31, 2007 | 12:43 AM
lxl_Jeffro_lxl's Avatar
1987 E300 TD
Depo rules!
Old May 31, 2007 | 01:25 AM
raymond g-'s Avatar
99 E320
https://mbworld.org/forums/showpost....5&postcount=25
here's a clue....
Old May 31, 2007 | 09:34 PM
43fatman's Avatar
2001 E430 Sport
That did not really help me alot . I should ask who makes the best Quality projectors. and where to buy? So no one on here has In Pro named lights?
Old Jun 1, 2007 | 01:17 AM
raymond g-'s Avatar
99 E320
there is logical connection. Quite a number of folks here have performed
retrofits on Depos using HID projectors. Depo makes InPro sold headlights.
Your question was whether anyone has done HID retros on InPros. Is this
making any sense.....yet?
Suggest that you search using keywords "depo hid" and reviewing the many
projects undertaken by forum members.....using Depo.....which makes the
headlights labeled InPro.....
The 'best' quality projectors are from Depo, in my opinion as they have the
best construction. This is a relative standing, however, as all the aftermarket
projector headlights for the w210 are not as rebust and well put together as
the OEM headlights.
Furthermore, the Depo projectors (bowl/90mm glass lens) suck. So if your
goal is for a quality and precision beam, you need to remove the projector
and replace with OEM HID projector. The top candidates are E55 bix and RS6
bix because their physical dimensions make them near perfect drop in....with
minor modification.
Again, recommend that you read the threads.
Where to buy? Autodynamics dot com....Ebay (but can be challenging to
identify). If unidentified manuf which resembles, be sure to clarify and ask
the vendor who the manuf is.
