Spring Pad question
Spring Pad question
The size of my rims are 19x8.5 (235/35) and 19x10 (265/30). I'm thinking of going H&R springs with #1 pads up front #2 pads in the rear...has anyone gone this seteup before? The reason why I'm thinking of the setup is because I don't necessarily want the back of the car "lower" than the front. If the car will sit even with #1 pads all around then I'll do that...
98 E320 (W210)
Leon
98 E320 (W210)
Leon
the car will sit even with #1 pads all around, but with our 210s having a different height at each fenderwell it gives the appearance of the rear being lower, most people who have a problem with this do what you were planning on doing. Using either a number 2 or 3 pad in the rear will make the front slightly lower than the rear, giving the appearance of an "equal" drop.
