Does your e430 make alot of noise on start up?
Old Oct 11, 2002 | 01:27 AM
dallasdriver's Avatar
99 e430 Green
When I start my car, it makes a very high rpm sounding engine noise is this normal or should I take it in? The noise is some what a grinding chhhh after the engine has turned over and then a big rev. I just got the car used, the owner was my dad's friend he changed the oil every 5k with Mobil 1, and the car only has 14k on it right now.
Old Oct 11, 2002 | 12:53 PM
jago1244's Avatar
2016 G63 ; 981 boxster GTS
i dont think i've ever noticed that with my car, but i have no idea what it could be. good luck.
Old Oct 11, 2002 | 03:24 PM
DSMIT's Avatar
1993 MERCEDES BENZ 300TE
could be vaccuum pump.runs for about 2 minutes,then stops,sounds like a vaccuum cleaner.
or even the air pump for emissions purposes
Old Oct 11, 2002 | 06:48 PM
Dema's Avatar
i535
I believe it's normal. Every car I knew had higher RPM just after start of engine which goes to normal after few seconds.
Old Oct 11, 2002 | 08:08 PM
99 e430 Green
thanks yall
Old Oct 11, 2002 | 08:33 PM
Juke-box's Avatar
SLK 350 '05
i think its normal too. all the mb's that i've driven do rev higher for a minute or two before settling into a lower rpm when first starting the engine..
Old Oct 14, 2002 | 10:36 AM
6.3's Avatar
6.3
2003 s500 sport
I also agree that after you start the engine revs faster, my 98 e430 does that as well as my 71 280sel 4.5
I don't know about the noise. I find the e430 really quiet even on start up. The 4.5 is another story.
Old Oct 14, 2002 | 11:40 AM
Chad Oliver's Avatar
E320
Only on a cold start should it rev higher. That is the Choke adjusting so your car doesn't stall out when you put it in drive. I would only run oil that the manufacturer recommends, mobil 1 is great if he's used it since day 1, but not all oils are compatible with the gaskets on various vehichles. This is especially true if you change brands of oil on a higher milage car that has been become conditioned to a non synthetic. You shouldn't have any grinding noises though.
Old Sep 4, 2013 | 03:40 AM
ChrisVoong's Avatar
e340
MY e430 rpm is high when engine start and it's not going down.
Hello, same thing for my car i have an e430 140k miles,Today after work i start my car and started making a very High RPM sounding engine noise i waiting for the RPM go down but doesn't after i step on the brake the RPM went down to zero but when i let go the RPM went back up above 1 now. Anyone got an answer? 9-2-13....
