Check Engine Light at idle
Old Jun 15, 2007 | 05:40 PM
melinda_bob's Avatar
I am sure this has been discussed but I couldn't find it.
I have a 99 E430 with 61K. My wife let it idle last week for 25 minutes and the check engine light came on. No other differences in vehicle (idle normal, etc.) After I drove it around for 15 minutes at regular speeds, the CEL went off. It has stayed off until today when I drove it in stop and go traffic for 10 minutes and then at a stop (idle) for 2 minutes - the CEL went on but when I got back to non-low rpm speeds it went out.
It is difficult to figure out the problem since the light keeps going out.
Anyone experience this???
Many Thanks
Bob - Vienna VA
1999 E430 61K
Old Jun 15, 2007 | 05:49 PM
csumt76's Avatar
LS7 powered Corvette
The fault codes will remain stored in the control module regardless.
I would guess fuel mixture adaptations, because of a faulty air mass sensor. Chances are you have faults for the left and right bank mixture adaptations at idle speed going in and out range because of incorrect air mass readings.
Old Jun 18, 2007 | 04:53 PM
starbrite's Avatar
2004 E320
Go to any Autozone store and they will do a fault reading with their OBD reader @ no charge.
